Laotto Indiana/ 9-14- / Div. 2 pull
Kevin Banet
09-09-2003 20:13:58
Laotto Indiana is having a pull at Laotto Community Pull at 9:00 AM. sunday, Classes are div. 2, 2800, 3500, 4500, 5500, 6500, 7500, 8500, 10000. Classes are a $10.00 entry. Trophies for top 3 places, money classes of same weight are right after the trophy class. Must pull in trophy class to be legal for money classes. Money class, one entry per tractor. Trophies classes may pull twice but tractor may only win 1 trophy. Money class 50% pay back. Auburn Indiana rules/ Tire sizes. Whelly bars are not required but are highly recommended without tractors have to run two inches low on hitch. all pull distence. info-call (260)637-7608.
Steve
09-12-2003 07:09:57
 Re: Laotto Indiana/ 9-14- / Div. 2 pull in reply to Kevin Banet, 09-09-2003 20:13:58
Hey Kevin Banet! How's the Slow Mo runnin. Still burnin oil like it usuallt does I assume? I know someone who used to work on one of those Minny's and they said if you get a 12 ga. and run a deer slug though the block it won't smoke anymore. I wasnt sure if you were going to the pull or not because they are havin miget wrestling in Fort Wayne this weekend and I was almost positive you would want to defend you belt. Oh well I hope to see you at the pull. Slow MO. ERRRRR .
Slow Mo's Mama
09-12-2003 13:39:35
 Re: Re: Laotto Indiana/ 9-14- / Div. 2 pull in reply to Steve, 09-12-2003 07:09:57
Hey Steve ????, I guess if you want to know about slow mo, you should ask the guy who owns it, and it's not Kevin. I assume by your sarcastic tone, that you've been beaten one too many times by the yellow monster, sorry about your luck. Maybe you should invest in a yellow one, than you wouldn't be so bitter. And the next time you want to rip on someone learn how to spell first, you spell midget with a "d". Your welcome for the spelling lesson. P.S. Minny Mo is running great!!!!! So go ahead bring your "tractor" to LaOtto, so you can get spanked! Yours truly, Marcy.
dctom
09-11-2003 10:38:00
KEVIN; JUST WHERE IS LOATTO? MAY TRY TO MAKE IT IF NOT TOO FAR DCTOM
kevin banet
09-11-2003 18:59:45
 Re: Re: Laotto Indiana/ 9-14- / Div. 2 pull in reply to dctom, 09-11-2003 10:38:00
12 MI. SOUTH OF KENDALLVILLE In. on state rd. 3 or 12 mi. north of I-69 at Fort Wayne In. on State Rd. hy 3.
kevin banet
09-10-2003 21:02:29
bud,call me i will try to answer your questons (260)637-7608, 18in. from center of axle 18 in.hight from ground,in all classes but 2800&3500,they are 16in. 2in. less with out wheely bars in all classes.(2800;)132sq.in,-(3500;)145sq.in,(4500;)175sq.in,(5500&6500;)200sq.in(7500;)252sq.in,(8500&10000;)300sq.in.un less a( 10000) tractor came with bigger size thein it's OK this is our tire sizes.front weights need to be reasonable close to front, 3mph.speedlimit.power blocks are ok!or like size engines. home made hitches are also ok.hope this helps,(KEVIN)
kevin banet
09-10-2003 20:56:46
pllr
06-01-2006 18:48:34
 spencer,wi sat, june 3rd in reply to Kevin Banet, 09-09-2003 20:13:58
BUDD
09-10-2003 17:41:46
Kevin; Where can I find a set of the rules? tire size, hitch height, hitch from center of axel. Thanks for the inf BUDD
k.b.
09-10-2003 15:49:03
Yes, we will be giving 100 pounds to all classes for all wheeley bars!!!are you coming over we love to pull agaist you?I believe we might even bring over the 8n.
Dick L
09-10-2003 18:09:15
 Re: Re: Laotto Indiana/ 9-14- / Div. 2 pull in reply to k.b., 09-10-2003 15:49:03
Well then I will not take away that love. I just got the wife to give me the OK. The old Oliver 77 lost power over at Oakwood, after the Bride told me I could pull Sunday, I brought the 77 up to the shed and stuck the charger on her, lifted the side curtian and see a crack had opened up in the intake. Squirted some loctite in the crack and plastered it with some blue gasket stuff. Should be good anuff to pull against old smoky slow mo.{:^D
Dick L
09-10-2003 11:36:09
Are you using the Auburn rules for the chicken bar weight?
