44 B JD
Scott
09-08-2003 19:45:25
Put my 44 B JD in my first pull this weekend. It's completely stock and I powered out at 93 ft. Any suggestions or tips would be appreciated.
Wendel
09-10-2003 16:35:00
 Re: 44 B JD in reply to Scott, 09-08-2003 19:45:25
Depend how much you want to do and if all this tractor will be used for. What size tire are you using go with a shorter tire but wider also its not to expensive to have block bored to later B gas piston and they are not hard to come have heard of going .045 over (4.732 bore) but the sleeves get thin or casting pits or if you really want to spend time and money power block,stroking.
