? for CHADS
MM
09-08-2003 12:04:10
Hey Chads I was wondering if you know of anybody that regrinds or makes cams for the smaller Farmalls. A,B,C, and such. Thanks.
ChadS
09-08-2003 19:29:31
 Re: ? for CHADS in reply to MM, 09-08-2003 12:04:10
Yes, I know a few folks who can regrind cams, Just need a cam and some info about the engine. As far as other options, The 154ci gas engine from a 203 IH combine is a good camshaft grind for the A-SC. Just my opinion, Hope this helps, ChadS
MM
09-08-2003 22:21:33
 Re: Re: ? for CHADS in reply to ChadS, 09-08-2003 19:29:31
What I have is a Super A that I put 3 1/4 with a slight dome (Tisco Kit) and new valves and guides. A good rebuild. I went from 113Cid to 132 and had the head cut about 020. Its nothing really special but its fun and I was looking for a little more power to play with. Thanks for the info MM.
ChadS
09-09-2003 09:28:31
 Re: Re: Re: ? for CHADS in reply to MM, 09-08-2003 22:21:33
You could do a little carb work, might be good for lugging power. My nieghbor has a Super C thats pretty strong. I also have a 56 cub low boy, great mower!! How much compression does it have? ChadS
MM
09-10-2003 22:11:04
 Re: Re: Re: Re: ? for CHADS in reply to ChadS, 09-09-2003 09:28:31
The carb I have is a Carter UT. At the moment I don't have the tractor at the house to check the compression but I have a 140 head (big valves and small chamber) on the bench waiting for a little work.
