farmall super m
kendall
09-08-2003 11:55:34
My buddy wants to get 80 - 100 horses out of a super m. I myself am a allis guy where should he start to get the extra power? He is thinking about the 350 cu in stroker kit from dennys. Is that worth the money or should he check other places? He pulls div 3 mph. Any help appreciated.
Doug in OR
09-08-2003 19:04:39
 Re: farmall super m in reply to kendall, 09-08-2003 11:55:34
That kit is $3000+ the last I looked. And that doesn't include labor. Denny's only claims nearly 100 hp when you include it with his carb, his manifolds (which I believe are now illegal under NATPA), his electronic ignition. For DIV 3, you have deeper pockets than I do. You sort of mixed div 3 and the mph together. If you are saying that you also have a 3 mph speed limit, the extra horses will do you little good. You can get nearly 3 mph from only a slightly hopped up SM - at far less cost.
Just my two cents.
HMMMMMMMMM
09-08-2003 13:36:15
No, our 281ci beats a 350ci farmall everytime it pulls with it....he prbably should look into the 4020LP pistons and a 6 1/4 stroke or w/e their running...someone else knows what i am talking about
WILDMAN
09-18-2003 12:22:28
 Re: Re: farmall super m in reply to HMMMMMMMMM, 09-08-2003 13:36:15
JUST BECAUSE ITS GOT MORE CUBES AIN,T ALL THERE IS TO IT.
bud barenie
09-10-2003 20:53:04
i've got to butt in here
4020lp john deere pistons and 6-1/4" stroke.
do they work together with stock rod's !!!
sorry i'm stupid , need some info !1!!!!!
Flogger
09-12-2003 09:11:13
 Re: Re: Re: farmall super m in reply to bud barenie, 09-10-2003 20:53:04
4020 LP pistons, 6 1/8 stroke, M rods.
Flogger
09-09-2003 14:48:18
Put some 16.9 X 38s on that 281, load her up to 7200 lbs, and stick her in second gear and you'll see what you aint got.
Farmall boy
09-11-2003 13:29:00
 Re: Re: Re: farmall super m in reply to Flogger, 09-09-2003 14:48:18
We will load her up to 7200, pull first gear and
show you what you've wasted money on
Flogger
09-12-2003 09:09:01
 Re: Re: Re: Re: farmall super m in reply to Farmall boy, 09-11-2003 13:29:00
You reckon?
