Timing a stroked motor
Ted
09-06-2003 07:00:34
Does that the initial timing need to be advanced beyond the factory spec when an engine is stroked?
TimC
09-06-2003 19:23:43
 Re: Timing a stroked motor in reply to Ted, 09-06-2003 07:00:34
You need max cyl pressure at a specified crank angle post TDC. If you are running an open chamber with no dome that the flame front has to travel up and over and around then you may only need a slight amount of advance past the factory setting. This is just my uneducated opinion.
Andy
09-06-2003 07:23:45
I would time it to specs to get it running and fine tune it on a dyno.
