The Ideal Gas Law....
G-MAN
09-05-2003 15:40:40
Can someone post the formula for the Ideal Gas Law? I believe that was the name of the formula used to calculate compression ratios based on cranking compression numbers and environmental factors. We're having a discussion about compression pressures and ratios on another forum, and some guys are interested in seeing the formula. Thanks in advance.
Jerry B
09-08-2003 08:18:39
 Re: The Ideal Gas Law.... in reply to G-MAN, 09-05-2003 15:40:40
It is called the Universal Gas Law.
If you can get in touch with G-Taylor, who used to visit this board regularly a few years ago, he can explain it better than anyone I know of.
Goldsburg
09-08-2003 08:17:12
Remember this discussion...?
D13
09-07-2003 04:30:38
Pressure X volume = Number of molecules X r (gas constant x temperature. PV =nRT
Given that 1 atmosphere i 14.7psi absolute, and R is a constant, the formula can produce the obvious conclusions:
Better cylinder filling increases n
Forced induction increases N and initial P, but usually also T unless you're intercooled.
As P rises from compression (shrinking V), T will want to rise also. This is the way diesels work.
If someone had told me that gas physics actually applied to automobiles I would have paid a lot more attention in class.
I prefer the simple version for infernal combustion engines - suck squeeze bang blow
RJ-AZ
09-07-2003 07:42:04
 Re: Re: The Ideal Gas Law.... in reply to D13, 09-07-2003 04:30:38
I never heard of the ideal gas law but;there is an ideal stochiometric air/fuel ratio of 14.7 to 1. This is by weight not volume. For any given bore and stroke configuration you can only fill the cylinder under normal atmospheric pressure with so much on the intake stroke. This is where porting and valving are crucial. Run it richer on the scale more spark is required up to a point of oversaturation. Run it leaner and you get detonation or a lean misfire. Also hotter temps. are when leaned out.
rhudson
09-05-2003 21:46:50
i think that is ((pressure1 x volume 1)/temp1) = ((pressure2 x volume 2)/temp2) but its going to be more complicated if fuel is in the air (its not "ideal" anymore) don't bust a gasket.
champspa
09-05-2003 16:48:11
I think it looks like this ( old volume x old pressure x old temperature )=( new volume x new pressure x new temperature ) give it a whack
