Farmall sm Starter ?
Ed
09-04-2003 19:05:10
Runing 235# cranking presure,WHAT 3 bolt starter should i use. Will a sm-D WORK AND IM RUNING 12V
THANKS ED
Wide Front SM Puller
09-07-2003 14:47:35
 Re: Farmall sm Starter ? in reply to Ed, 09-04-2003 19:05:10
Don't waste your money, I have a SM with 265psi. The factory starter turns mine with no problem. Spend your money somewhere else.
randy hall
09-05-2003 19:38:18
how big is your engine ? i have a 298 c.i. m with 265# compression and the regular starter wheels it over fine.
Ed
09-06-2003 11:05:36
 Re: Re: Farmall sm Starter ? in reply to randy hall, 09-05-2003 19:38:18
Randy my c.i. is 312 m&w storker kit 4.125 m&w dome pinston and 450 LP head.CRANKING COMPRESSION 235#
TimC
09-05-2003 13:17:06
The 460 deisel should crank it if it mounts up properly.
The gear reductions from Lemmons make short work of getting one started but their machinist should have milled a little more out of the housing so you can get a wrench on one of the mounting bolts.
WILDMAN
09-05-2003 04:08:59
THAT STARTER SHOULD WORK. YOU CAN CALL LEMMONS TRACTOR THEY HAVE GEAR REDUCTION STARTERS.
Ed
09-06-2003 11:10:48
 Re: Re: Farmall sm Starter ? in reply to WILDMAN , 09-05-2003 04:08:59
What the $ for a Lemmons gear reduction starter? THANKS ED
