help with 88 pulling motor
RICH OLIVER
09-03-2003 21:12:33
I AM BUILDING S-88 PULING MOTOR ;3-7/8 DOME PISSTONS ,HEAD MILLED 55,BIGER VALVES,LITTLE STIFER SPRINGS,PORT&POLISHED,STROKED CRANK 7/16,USING 88 RODS,COMP.GROUND CAM,IT SHOULD BE 320 CUBES,I DONT KNOW THE COMPRESION FOR SURE YET MAYBE AROUND 10 TO 1.I AM LOKING FOR A CARB ,MAYBE OFF OF JD 105 COMBINE OR 7700 ? ANY COMENTS WOULD BE APRECATED. 620-342-0674
look in classifieds
09-04-2003 19:52:27
 Re: help with 88 pulling motor in reply to RICH OLIVER, 09-03-2003 21:12:33
see classifieds for carbs at reasonable prices
88 Power
09-04-2003 17:38:26
Rich,
The guys that posted before me gave good information and here's some more. The Deere 7700 gas combine used the 404 block I believe so the 1 7/8 or 2 1/8 carb will be too much if you're not spinning it. Plus unless you have a custom intake manifold built, it is pointless to hook one of these up to a garden-hose size stock S88 manifold. The GK195U carb, on the other hand, is a 1 5/8 throttle plate built for a 320 cube motor at 2200 RPM. I have one of these if you are interested. Again, manifold work will be required to get this to run right.
Also---you say you are using stock 88 rods and am assuming M&W 3 7/8 Turbo Domes, how are you making up for adding 7/16 of stroke? The M&W pistons are designed with a pin height for 4 inch stroke and 6 3/4 inch rod.
A.P.
09-04-2003 09:44:41
Are you planning on running a lot of rpm? If not then a carb off of a Waukesha 195, Massey 1100 or 1850 Oliver will probably work pretty good. Beyond that I would see one of the better carb people (Motec or ?). With carbs bigger isn't always better.
Good luck,
A.P.
David
09-04-2003 06:07:58
I have a NOS Zenith carb for a JD7700 that I would be willing to sell. Let me know and I will email you with details.
Hillbilly Hooker
09-03-2003 21:25:26
Contact Matt at motec engineering. E-mail me and I will give you his e-mail
Ollie puller
09-04-2003 08:04:29
 Re: Re: help with 88 pulling motor in reply to Hillbilly Hooker, 09-03-2003 21:25:26
The carb off of a 105 combine will be plenty. That is also the same carb used on 3o20-4020 Jd's.
The 7700 carb is an overkill for that motor.
