Hey John or Kevin Bannet!!
Farmall Daddy
09-02-2003 14:39:00
I was wondering if one of you guys know what the rules will be for the Laotto pull on the 14th. Will you need wheelie bars to compete or could you pull at a 16 inch drawbar. If not able to pull competition, in the exibition pulls, are you allowed 18 in. Fill me in on others rules such as speed, and what sled will be there. Haven't got the wheelie bars on the 560 yet, but would like to know what it will do. Thanks!!
kevin banet
09-08-2003 20:44:38
 Re: Hey John or Kevin Bannet!! in reply to Farmall Daddy, 09-02-2003 14:39:00
wheely bars are not required but you have to use 16 inch. hitch or 14inch in 3500'&2800 classes .2800,3500,4500;5500,6500,7500,8500,10000] we will also run all same classes as money classes one hook in money classes.all classes $10.00 entry.must pull in trophy class to be legeal for money class.
slow mo 57
09-03-2003 18:17:52
If you think some one is not right on rules like the 77 you said.The man was told the rules he said it was a misstake my brother said he lower it and dropped 10--15 feet it should not happen any more but he will be watchted a him a little closer.Let one of us no right a way & we will do are best to help.We are always moving & it is hard to see every thing going on.Any one can cheat and win but good pullers dont need to!!
slowmo57
09-03-2003 17:28:06
How did you do at Pauls pull?
Farmall Daddy
09-04-2003 18:12:50
 Re: Re: Hey John or Kevin Bannet!! in reply to slowmo57, 09-03-2003 17:28:06
Didn't do too bad. Guy with the WD Allis, I think his name was Jason? His girlfriend-wife drives the John Deere B in the 3500 lb class. That tractor has some guts in it. Looked under the shields, and it looked to have a combine motor in it. Him and Sarah ended up taking 1st and 2nd. If he is over to Laotto, take a look at his tires. I thought they were cut because the sides are real sharp, but yet there is a big notch in the center. On the Oliver, it has sharp tire tread all the way across it, but that is due to being drove to town all the time from the previos owner. I ended up being disqualified with the M because of the speed limit. The Terminator is the only sled that I like anymore. The others just don't match my tractors now. Did you or Kevin figure out if you need wheelie bars or not? Figured I'd ask you since you are a big part of the pull. Plan on making it over there, if we aren't busy. Thanks!!
kevin banet
09-02-2003 20:09:28
i'll check on tip bars,same rules as auburn.sled to be termatior.3/mph.
Farmall Daddy
09-03-2003 17:12:27
 Re: Re: Hey John or Kevin Bannet!! in reply to kevin banet, 09-02-2003 20:09:28
Like to bring the 560 along and see what she'll do before I get a lot of money rapped up into the wheelie's. If I could pull competion, let me know on what height I may be able to run with it. Also, are you and Laroo's running it because didn't know what places there will be. Thanks!!
