Pulling tractor....
Kevin
09-01-2003 10:56:13
I'm looking to start pulling(father and son)and was looking for advice on a good tractor to start with. Maintenance and budget are high on the list...Thanks to those who respond....
Kevin
jimbo skaggs
09-13-2003 15:07:27
 Re: Pulling tractor.... in reply to Kevin, 09-01-2003 10:56:13
i there just wanted you to know i have a 333 massey harris with a 44 motor it pulles 4500# to the 10,000# we have over 300 trophies over the last 4 years we have the tractor for sale because we are building another tractor we are asking 3,000 dollars for it you can see it on geocities.com/ckappuller the name of the tractor is daddy's toy you can call me at [270]358-0823 or [270]358-2214
dave
09-02-2003 17:35:46
we [father and son] just put a ub moline together with a tight budget and it is very compitive. we did the work our self. we also pull a super 88 oliver that we bought and is alot of fun and compitive. we might sell the 88 since the moline done and we only want to haul one. e-mail me if you got ? on building a moline or interesyed in oliver.
Bryan
09-02-2003 13:50:19
I might me inclined to sell my Moline U puller. It's on propane, it's nice, and it's ready to go. Send me an email if you're interested.
David
09-01-2003 16:08:58
I would start with a Minneapolis Moline U or UB. They are great tractors to build for alot less money than other tractors. It is easy to get 430 to 450 cubic inches using stock and readily available parts. They will pull from 5500 lbs. up to 8500 easily. If you don't mind a hand clutch, go with the U. If a foot clutch is your preference, go with the UB. Other than the clutches, they are basically the same tractor. If your rules allow it, you can just put a G Moline blocks, crank, pistons, and rods in a U or UB cranks case and have 403 cubes and about 75 to 90 horsepower easily for not much money. Or if your rules don't allow the taller G blocks, you can put on blocks from an M5 or later tractor with the 4.625 bore with the G crank and stock rods. Welter's sells piston for this combination. With the right heads, manifolds, and carburetor, you should have 120+ horsepower. Give Matt at Motec a call, he could help you with carburation, a distributor, and a governor for pulling.
Farmall Daddy
09-01-2003 15:29:18
Me and my dad started out on a Farmall M. With the 4 inch high domes in the motor, it will pull pretty competitively in the 4500-5500 lb. class. We had motor work done to ours and got 65 horse, and now she will go on up to 7500lb no problem. Let us know what class{s} you would want to pull in. That is the key factor.
