Starting Allis WD
KB
03-23-2001 10:45:49
Tractorod, how did you get the big allis motor to start? I am having the same problem on a 300 ci 12 to 1 motor in my WD.
Tractor Rod
03-23-2001 16:26:35
 Re: Starting Allis WD in reply to KB, 03-23-2001 10:45:49
KB I had to build a decompressor and go to 24 volts. Works real good and starts real easy. Tractor Rod
KB
03-25-2001 08:10:20
 Re: Re: Starting Allis WD in reply to Tractor Rod, 03-23-2001 16:26:35
Did you stay with the original starter..probabaly not..What did you use? By the way thanks for the info. My engine is only 300 cid so I was hoping I wouldn't need a decompressor.
Tractor Rod
03-27-2001 16:03:21
 Re: Re: Re: Starting Allis WD in reply to KB, 03-25-2001 08:10:20
KB I used a stock 6 volt starter. It seems to be holding up ok
KB
03-28-2001 10:35:29
 Re: Re: Re: Re: Starting Allis WD in reply to Tractor Rod, 03-27-2001 16:03:21
Thanks for the info. I had my stock starter rebuilt, got a good battery and new battery cables, and got the timing set right and it will start now.... but not by much. Have you pulled the 403 cid motor yet?
Tractor Rod
03-28-2001 15:22:17
 Re: Re: Re: Re: Re: Starting Allis WD in reply to KB, 03-28-2001 10:35:29
KB I have not yet pulled the motor. My biggest concern is it is in a unstlyed WC and I had to use the original zenith carb. Sure hope I can get enough air through it. Rod
