Whats a good antique puller?
Joe
08-31-2003 06:58:28
Whats a good tractor to pull in antique. I will do work, but dont want to spend thousands of dollars on the motor. I want plenty of hp, and will need it to compete. but whats good to start with
A different shade of red
08-31-2003 19:02:18
 Re: Whats a good antique puller? in reply to Joe, 08-31-2003 06:58:28
Alot of people are talking about Massey
Harris's.... well I have pulled with 3 44's that
were no stock tractors..pretty close....but not
stock and My Farmall M is except for a Super M kit
that boosts it 16 cubes to a 264....We tear them
up everytime we pull against them...i pull 4500 to
6500...they pull 4500 to 5000 maybe 5500.... if
yah got a good carb, ignition, manifold, and head
they are really competitive....TIRES ARE A MUST
FOR ANY TRACTOR!!!!!
marlowe
08-31-2003 11:51:12
MH 44 0r 44 special are as good as any and better then most in 4500 to 6000 see some real good Minne mos also and some IHC Ms
buickanddeere
08-31-2003 09:50:13
I maybe a Deere man but those Massey 44's are tough in the 4500lb class. A high comp/oversize sleeve kit, a cam, valve bowl porting and a larger carb is a 75 HP machine. And lots of traction with 15.5x38 Firestones. The 4500lb class is popular however. Fewer pullers in the 6500lb and up classes.
NY Deutz puller
08-31-2003 07:59:25
The best you can do is a Deutz D-50 or a D-65. Ask anyone who has one or has pulled against one. I am sure you would have the only one in your area and you will be the subject of alot of laughing until you pulled it. I know of a D-65 that is going to Fla. soon so watch out you Fla. pullers!!!! Now if I could just find some bigger tires for my 130-06 I may do better in the 10,500lb class. Having fun. NY Deutz puller
Krouthead
08-31-2003 08:23:50
 Re: Re: Whats a good antique puller? in reply to NY Deutz puller, 08-31-2003 07:59:25
I can fix you up with 1 of those little sweeties,check the classified photo section of this site.
LOL
Krout
