Liquid or Wheel Weights?
Tye
08-28-2003 19:05:17
I pulled my first pull with my JD 50 back in july. I have liquid in the tires as of right now because I use work it. It it better to have liquid for pulling or Wheel weights? Thanks for any advise
Neither
08-30-2003 05:40:54
 Re: Liquid or Wheel Weights? in reply to Tye, 08-28-2003 19:05:17
Weight racks with suitcase weights. You can put the weight where you want it.
laipuller
08-28-2003 20:39:36
wheel weights by far if you were gonna dedicate that tractor for pulling. that way you can put the weight where you need it if you have to move it around to balance your tractor. but if you just pull it once in a while at a local pull and still farm with it full time, then i'd leave it alone if it was me. good luck
