JD A Power Block
Jeremy Brault
08-28-2003 14:17:35
How far can you bore out a 6 inch power block for an A JD. I was hoping I could put in G JD pistions that are .125 over. Will the sleeves take it or do you have to resleeve it? Any help would be great. thanks
Jeremy
Eric
08-29-2003 06:35:49
 Re: JD A Power Block in reply to Jeremy Brault, 08-28-2003 14:17:35
0.125 over works just fine. Hinrich Repair sells 0.125 over pistons or you can cut down standard bore G pistons. Search this whole site for a guy named Dave Wickman or WTW. This guy knows his stuff when it comes to power blocks. Here is tip I got from him, do not have the shop boil the block when you have it bored. You risk damaging the sleeve's o-rings and having water leaks.
2 Cylinder
08-29-2003 07:13:40
 Re: Re: JD A Power Block in reply to Eric, 08-29-2003 06:35:49
I am running a Powerblock with 6 1/8" Hinnrich high compression aluminum pistons in a 47 JD-A. It Dyno's 55 hp without the crank being stroked.
Jeremy Brault
08-29-2003 09:05:16
 Re: Re: Re: JD A Power Block in reply to 2 Cylinder, 08-29-2003 07:13:40
ok. I am planing on boring it to 6 1/4". Will that work or not. does it need to be sleeved then or can it just be bored out.
Thanks
Jeremy
i think
08-29-2003 16:19:22
 Re: Re: Re: Re: JD A Power Block in reply to Jeremy Brault, 08-29-2003 09:05:16
i think just bored...lots of people run that setup with the G piston. It seems to work good.
61/4 will be too much
08-29-2003 09:11:41
