560 What classes should it be pulled in?
Farmall Daddy
08-27-2003 19:13:21
I bought a 560 this past weekend and was going to a tractor pull in Auburn to try it out this Saturday. Everything is stock on it. Motor, tires, hitch and all that stuff. At 65 horse, would it be able to pull in a 9000 lb. class? Didn't know if any of you guys out there have tried it or not. Thanks for any advice!!
slow mo57
08-27-2003 19:46:44
 Re: 560 What classes should it be pulled in? in reply to Farmall Daddy, 08-27-2003 19:13:21
You got a new toy that sounds like fun.What size tires is on it?If it has wrght tire size for the rules I would run it lighter.Butin low low it should be ok.What tractors are you taking?
Farmall Daddy
09-01-2003 15:49:52
 Re: Re: 560 What classes should it be pulled in? in reply to slow mo57, 08-27-2003 19:46:44
Want to take the WC, M, and the 560. Figured that the Laotto pull may turn out to be like Auburn. People have heard about it, so everyone will be there. The WC is starting to fall behind since that Oliver 77 rolled in. He got caught over to Auburn with an 18 inch drawbar, but I went over there and reminded the guy at the scales to double-check his. I guess he was disqualified according to Kevin. The 560 has 15-5-38's on it, fluid in them, and it even has fluid in the front too! Weighed in at 7440 w/ me on it at the feed mill up to Ashley. Will I be able to pull at an 18 inch or will I have to pull down to a 16 inch since I don't have wheelie bars on it? Let me know on the rule of that!! P.S. It is all stock, motor, tire, hitch, etc.
