PISTONS
DWIGHT
08-27-2003 18:16:58
I'am STILL LOOKING FOR A SET OF FOUR PISTONS 4.250 DIA. THAT I CAN RUN IN A M BLOCK.THANKS
Chads
08-29-2003 12:52:51
 Re: PISTONS in reply to DWIGHT, 08-27-2003 18:16:58
I have seen a 4.25 bore M that still had the sleeves in it. I don't know if they bored a 450 sleeve out or what piston was exactly, But on certain blocks, when you pull out the sleeve, it leaves a counterbore in the block where the sleeve sets in. I have seen blocks with the sleeves out, some measure 4-3/8s and the later model blocks measure 4.5 at the sleeve grooves. If you still have the groove in the top of the block, it may be difficult to install the piston assembly, in the bore due to the rings not clearing the counterbore. Hope this helps, Chads
randy hall
08-28-2003 09:18:28
believe it or not of the two people selling this size piston denny's is the cheaper of the two.
IRISH RED
08-27-2003 20:20:25
did you bore your m to 4.25 and do you still run water in the block I think a 454 chevy is 4.25
DWIGHT
08-27-2003 20:55:53
 Re: Re: PISTONS in reply to IRISH RED, 08-27-2003 20:20:25
i have not bored it yet but i will before long. i plan not to run sleeves. yes it will have water.
