Track in batesville
Mr Animal
08-25-2003 17:01:05
For all those pullers that have reservations about the track at and for the Batesville pull on Sept 6th, the county will be on the job this week. I have been told by the fair board that they will cut the hump out of the track, remove the grass, and level it with a grader, then water and pack it. The track conditions should be great for the pull. So you pullers that just got off the road, fuel them up and head to Batesville and those that havn't pulled for awhile, blow off the dust, charge the battery, fuel them and come on too. We hope to see all of you there. Thanks, ANIMAL
Krouthead
08-26-2003 04:12:51
 Re: Track in batesville in reply to Mr Animal, 08-25-2003 17:01:05
I am glad to hear that!!I hope you double check on the prep crew,dont want another Salem track.
See Ya
Krout
Mr Animal
08-26-2003 05:10:48
 Re: Re: Track in batesville in reply to Krouthead, 08-26-2003 04:12:51
Krout, I will try to stay on top of the crew as best as one can stay on a county crew. We will do and hope for the best. Thanks. Animal
PISTON
08-26-2003 18:16:03
 Re: Re: Re: Track in batesville in reply to Mr Animal, 08-26-2003 05:10:48
WELL WE WENT TO MALVERN PULLED ON SAND TRACT THEN WENT TO MT. IDA PULLED ON GRAVEL RD. SO I WELCOME A GOOD GRASS TRACT.OR WHAT EVER YOULL COME UP WITH.I DONT HAVE SPECIAL COLORED TRACTOR, QUITE UNIVERSIAL I THINK...
sos puller
08-26-2003 20:11:40
 Re: Re: Re: Re: Track in batesville in reply to PISTON, 08-26-2003 18:16:03
WHERE IS BATESVILLE AT SOUTHERN ILL????? ??
Wide Front SM Puller
08-26-2003 21:03:42
 Re: Re: Re: Re: Re: Track in batesville in reply to sos puller , 08-26-2003 20:11:40
Arkansas, come on down!! You will have a good time, win or lose. That is the way it should be.
