MSD Hot Box
Wide Front SM P
08-20-2003 16:53:51
How much hp will a MSD "hotbox" give a IH Super M. I already have all the other stuff to support the extra fire, just want to know if it is worth the money.
buickanddeere
08-21-2003 21:34:05
 Re: MSD Hot Box in reply to Wide Front SM Puller, 08-20-2003 16:53:51
It won't add power but it may ensure the engine puts out all the HP built into it.
jcm
08-21-2003 14:45:29
I can tell more going down the track than what a dyno does says...I'd recomend one.
JDGnut
08-21-2003 06:48:03
SM... Sorry this is off topic.. but do you know the date for the Cleveland, MS pull.. JDGnut
08-21-2003 15:56:01
 Re: Re: MSD Hot Box in reply to JDGnut, 08-21-2003 06:48:03
Not sure of the date yet, I will call G. R. and see.
JDGnut
08-21-2003 16:50:12
 Re: Re: Re: MSD Hot Box in reply to Wide Front SM Puller, 08-21-2003 15:56:01
Thanks.. scheduling work so I can be that direction the begining of Feb..
Bryan
most people say...
08-20-2003 17:52:29
that it starts easier, runs a little smoother, but no hp gain unless your old system just sucked.
Chads
08-20-2003 18:49:31
 Re: Re: MSD Hot Box in reply to most people say..., 08-20-2003 17:52:29
Yes, you are correct. It helps all the above. Chads
ChadS
08-20-2003 17:09:51
None, A good ignition system is essential. but a good electronic or points will be fine for pulling. A good coil, I ran a MSD6A, with the timing control, just for the timing comtrol device. HP, did not increase at 540, but the engine runs more efficent. Chads
Ohio H
08-20-2003 17:09:51
Don't know about horsepower, but I need to know what MSD box to use on a hot H with petronix and hot coil. Thanks,.....H
Chads
08-20-2003 19:01:51
 Re: Re: MSD Hot Box in reply to Ohio H, 08-20-2003 17:09:51
You have a good combo already. I am still running points with a Accell Super coil on Something Wilder. I recalibrated the fly weights in the distributor, thats it. Chads
