JD G power Block??
Robert S
08-20-2003 11:55:45
If you put a 6.5 inch power block On a G and a gas head from a 70 JD Does anyone know what the compression ratio would be or close to??
WTW
08-22-2003 06:54:16
 Re: JD G power Block?? in reply to Robert S, 08-20-2003 11:55:45
Robert, A John Deere "Gas" 70 head will not bolt up to the "G" Powerblock. A "All Fuel" 70 head will, but has the same combustion chamber size and valves as a late "G" head. If you put a mid series "G" head which is flat will raise your compression more than you will want with a stock "G" Powerblock piston. Usually this is the head people use with a shorter piston to control compression ratio. My best luck is around 9 to 1. Good Luck Dave W.
