What cam to use?
Jack
08-28-2001 09:30:50
I have a 52 G John Deere and this winter I am going to freshen it up with new pistons and rings.I was wanting to know about putting some other kind of cam in it.What would be a good one to buy and who from?Thanks fellas,Jack(TN).
Gman
08-28-2001 18:39:52
 Re: What cam to use? in reply to Jack, 08-28-2001 09:30:50
Jack your "G" should have a F-900-R in it which is a good cam,also I've got a 720 gas grind in my puller now that seems awful good,it's handleing a bunch of cube's. Gman
burns
08-28-2001 18:34:32
Hey Jack,
I take it you did not decide to part with your G. I added a Dengler cam which I have been extremely pleased with. His cam is in a few G's locally. I am not aware of any cams from Robert's carb but I hear they are good. A fellow puller added a cam from Vintage engine in his Dad's A that lugs very well. Drop me an email if you have any questions.
Gman
08-28-2001 18:59:37
 Re: Re: What cam to use? in reply to burns, 08-28-2001 18:34:32
Hey burns did you see in the last issue of Hook magazine,Jerry's Machine shop is offering some new blocks for 70's and Fat "G"'s if his blocks are as good as his heads they are good one's,looks like you want have to run a spacer with them boy that will be a plus if that is the case,been pullin any down this way it's been to wet or I'm working if it keeps raining,fellow might take a look at putting tracks on the "G". Gman
burns
08-28-2001 20:47:38
 Re: Re: Re: What cam to use? in reply to Gman, 08-28-2001 18:59:37
I actually saw one of Jerry's blocks in a G at the NY expo. A couple of dead give aways are the petcocks on the underside of the block, upper water pipe mounting platform is raised and shifted a little towards the rear of the block and the mounting studs closest to the side rails are replaced with allen studs. Part of the crank case had to be cut out on the clutch side to allow the sleeves into the case.
You know what it is like to fit a stroker crank in a case but he had just as much trouble with the block getting in the way of the cam, timing gear, and the case.
The latest prices are around 4500 for block, 800 for pistons/rings/pins, 1600 for the head/manifold. I understand Jerry was having some troubles with getting the pistons. I guess a block is being sent to a popular puller in the midwest to be placed in a already strong 70. You know how brothers can be with their 70's and A's
agco puller
08-28-2001 13:33:24
Hi Jack I'm no JD expert but I would call Murphy's Motor Service in Hallsville, Missouri. They make roller rocker arm's that effectively increase your stock
cams lift and duration. You should increase your compression ratio to effectively utilize going to a wilder cam. The ratio they list are 2.0 for a JD G, I hear they are excellent products. There phone number is (573) 696-3655. My JD source uses these exclusively on big cube JD engines.
