Pulling my B
driver
08-27-2001 19:35:04
I'm going to pull my b next year and need some advice on getting a lot more power....where should I start,stroke or bore or both and how about a good cam any info would be helpful.
tim
08-28-2001 18:38:15
 Re: pulling my B in reply to driver, 08-27-2001 19:35:04
You will want to make sure you have good tires with good tread. All the power in the world won't do much good wothout any traction.
What Brand?
08-28-2001 12:07:52
Allis Chamers,Farmall,John Deere or Custom?
Russ
08-28-2001 10:27:33
If you have one of newer "b"s 1947 and up and they make you pull in low gear you don't need more power. You will be competive in the 4500 lb class ONLY if you are pulling against truly stock tractors. These days that is pretty hard to find. As a B with cast rear wheel weighs about 4200 it will be difficult without major changes to get in a lighter class. Russ
Dale G
08-28-2001 09:11:36
Unless you are planning on pulling in the 3750 and lighter classes,you would be better off using an A to pull with Good Luck
burns
08-28-2001 08:28:41
The stroke is were you are going to gain the most hp. .090 & .125 over pistons will only gain you a few hp. New aluminum pistons will reduce the weight of the reciprocating parts and the rod length will determine your compression.
I am a firm believer of the ol' saying that any tractor can be beaten on any day/night regardless of hp/performance (within limits). With that said, it has been my experience and opinion that a JD B is not the best choice in models when it comes to pulling. Unless you stay in the really light classes, you are going to be facing unstyled/styled JD A and other higher hp tractors. Obviously you are going to invest some money into you project maybe the thoughts of a different model should be considered.
pete
08-28-2001 11:34:33
 Re: Re: pulling my B in reply to burns, 08-28-2001 08:28:41
putt-putt-bang-bang
putt putt
08-28-2001 18:26:32
 Re: Re: Re: pulling my B in reply to pete, 08-28-2001 11:34:33
4 first
1 second last saturday
pulled 3rd gear 6000 and 6500 open class & 2nd 8500 open
How is your piece of $hit or do you still not have a tractor you grandstand mechanic.
pete
08-29-2001 10:08:51
 Re: Re: Re: Re: pulling my B in reply to putt putt, 08-28-2001 18:26:32
knowing ol' burns, he was probably the only won there pulling! if anyone else was there in was just a junkier and stocker JD than his piece. putt putt bang...putt bang
burns
08-29-2001 14:50:45
 Re: Re: Re: Re: Re: pulling my B in reply to pete, 08-29-2001 10:08:51
Boy I missed you guys and your wonderful since of humor. Once again I have been touched by your kind words.
ha ha ha ha ha ha
You guys are to much.
HEY LOUD MOUTH
08-29-2001 08:37:26
CONSIDERING YOU WERE THE ONLY PULLER THERE IT'S HARD TO FIGURE OUT HOW YOU GOT SECOND
Gary
08-29-2001 07:40:16
What were you pulling against?
putt putt
08-29-2001 16:52:37
 Re: Re: Re: Re: Re: pulling my B in reply to Gary, 08-29-2001 07:40:16
Hey Gary how has your pulling season been going? If you are asking if I was pulling against tractors like the Big Voodoo Daddy, Hutson's W-40, or Wein's A/70. No, I was up against a variety of local strong running tractors (Farmall John Deere, Oliver, Ford, and Massey)
Don't misunderstand my post on how I did. I am not the type of person to boast on the results of a pull. I haven't posted much the last couple of months because I have been working away from home. I just remembered how much of an a$$hole the Pete charater was and still is.
Burns
Gary
08-29-2001 17:28:50
 Re: Re: Re: Re: Re: Re: pulling my B in reply to putt putt, 08-29-2001 16:52:37
Thanks I was just wondering what folks were pulling in your area.
crankshaft
08-28-2001 06:12:02
what year and tire size do ya have?
driver
08-28-2001 19:37:46
 Re: Re: pulling my B in reply to crankshaft, 08-28-2001 06:12:02
evrybody seems to think that my B is not the thing to pull I have a super c would that be more competitive? I just figured it was to small.
