Farmall M
Devin
08-18-2003 15:29:49
I am geting ready to rebuild my Farmall M because i am only geting 30 pounds of compresion. I was wondering what i could do to get more power out of it when i am done rebuilding it. Could I put sm pistons and sleves in it? It all ready has fire crater pistons and a 8060 head. Or should i just rebuild it with the same pistons again? I cant build it up to much because i still have to use it here on the farm. I was reading about posi trac in the M. I was wondering if it is a good idea or not. To me it sounds like you would break some thing by the way thay work.
GARY ANSELL
08-20-2003 19:50:23
 Re: Farmall M in reply to Devin, 08-18-2003 15:29:49
TELL ME MORE ABOUT THE POS TRACTION REAR END IS IT BETTER FOR PULLING?
WE HAVE A SUPER MTA
Chads
08-18-2003 16:39:40
No breakage in the posi limited slip kits we offer. A limited slip would be best for under 10mph. Sounds like you blown a head gasket. Check out the post hera at yt under "M-450" Chads
GARY
08-24-2003 23:17:48
 Re: Re: Farmall M in reply to Chads, 08-18-2003 16:39:40
WHERE CAN I GET THESE PARTS DO YOU HAVE A NUMBER?
THANKS GARY
