Need suggestions
light H
08-18-2003 13:45:49
I have a 3000 pound farmall H would like to make 100 hp motor for it. Is this enough to pull 4th gear with 13.6 38 on clay track. what stroke bore and compesion ratio do i need to get this. all help appercated tired of lossing to 5th gear olivers and 3rd gear ac. thanks light H
ChadS
08-18-2003 20:07:44
 Re: Need suggestions in reply to light H, 08-18-2003 13:45:49
100 hp is enough to pull 4th with 13/38s. A 270ci, 3-13-16 bore, 5-3/4 stroke, good cam, H-350 gas head (machine work) about 300psi at cranking speed. I ran an engine like this for years, very competitive in 4,8,12mph classes. With a strong engine, proper weight placement, and other little details, you could run with them. Chads
Ohio M Puller
08-19-2003 05:04:49
 Re: Re: Need suggestions in reply to ChadS, 08-18-2003 20:07:44
Chad
What piston do you use to get 3 13/16? As well which cam did you choose. I do have a few more detailed questions to ask. Email me if you have a chance.
Ohio M Puller
ChadS
08-19-2003 07:41:31
 Re: Re: Re: Need suggestions in reply to Ohio M Puller, 08-19-2003 05:04:49
806 gas
