SATPA at Big Spring,Tx. 8-23-03 ???
Dale in Tx.
08-17-2003 18:32:47
What time?,what rules? what classes??
Sandyland Puller
08-18-2003 07:28:58
 Re: SATPA at Big Spring,Tx. 8-23-03 ??? in reply to Dale in Tx., 08-17-2003 18:32:47
The pull Will be starting at 1PM Registration beginning around 11 AM at the Howard County fairgrounds. We have a stock class Division 1 rules hang on weights allowed. Modified Class 15% over RPM, 6 MPH Division 3 Rules basically.
Open class 15% over RPM No Speed limit.
Drop me an email if you have any other questions. If you have a fax number let me know and I will get you a set of rules.
Dale in Tx.
08-18-2003 19:46:24
 Re: Re: SATPA at Big Spring,Tx. 8-23-03 ??? in reply to Sandyland Puller, 08-18-2003 07:28:58
Hi sandyland puller, Thanks for the info.Hope to be there Sat. Will be pulling stock, div.1 with a case 400 also guess I will haveto haul my little buddy and his JD70 so I will have someone I can beat(some time). hope to see you'al there. Dale in Tx.
JDGnut
08-18-2003 18:44:58
Scott... Where is the Donald Handcoch Memorial pull??? How light have you gotten the B down too... and Hows the G running... JDGnut
Sandyland Puller
08-19-2003 06:21:19
 Re: Re: Re: SATPA at Big Spring,Tx. 8-23-03 ??? in reply to JDGnut, 08-18-2003 18:44:58
I can only get the B to 4100# Those Deep Treads I have on it are heavy but they have a good bite. The G is running pretty good I am still getting used to it. I just a LP Ignition on it to try to pep it up a little more so we will see. The Memorial Pull location is Up in the air at the moment it will either be in Brownfield or Plains. Are you coming to Big Springs it is not supposed to be too hot this weenkend.
