engine builder
Louie
08-15-2003 19:03:05
I need to find a good engine builder that would be knowledgeable with a Buda 262 gas out of a D-19 that we're puttin in a Cockshutt 40. I am located in NE Ohio, and none of the local machine shops will do anything to a tractor motor unless it is "whats in the book"...in other words, they won't touch it unless they have the exact factory specs. (???)...any help is appreciated. thanks
Jeff
08-17-2003 16:31:46
 Re: engine builder in reply to Louie, 08-15-2003 19:03:05
There is a shop here in Northwest Tn that has built a few tractor motors for some guys around here. I am not sure how much he does to them but they all seem to run great. His business is Kelly's Engine Service in Union City Tn. he normally builds hot rod.dgar race engines but seems to quite good at most anything. His phone number is 731-885-7411.
L Hud
08-17-2003 07:25:39
If you want a Buda built, there is a shop in Jasper,IN. they know the engine in and out. I can't remember their name only the location. Hope this helps.
Jason Snyder
08-16-2003 13:18:16
Call Butch Gilger, owner of Mets Machine Shop in Mansfield. 419-522-4111. He has built several very good running antique tractor engines as well as hot farm and super farm engines.
David
08-16-2003 15:02:23
 Re: Re: engine builder in reply to Jason Snyder, 08-16-2003 13:18:16
I've had the "pleasure" of having Butch do some blocks for me. I told him I needed water to run through them and he said ok. Went to pick them up and they were filled solid with block filler. Told him that wouldn't work, he said find another set of blocks and he would pay for them and fix the problem. Said ok and left and was going to find some other blocks to redo when he called the next day. Seems he didn't want to take a lose on the blocks, said he would press the sleeves out and try to drill the block filler for water. Got the blocks back and guess what, they leaked! Called him and he said run some block sealer through them. Done it 3 times and they still leak. Now he says there is nothing he can do about it. It was all his fault, but he dosen't stand behind his work or mistakes. Stay far away from Met's. I now have a set of $1200 boat anchors!
farmer don
08-16-2003 11:31:49
Have you tried Center Automotive in Akron?
