need info on jd head gaskets for high compression
mark
08-13-2003 19:34:11
i have been blowing out head gaskets on my 47 a need info on a all metal coper gasket will it work and will it hold up to high heat burnt my out last weakend i am from kansas. have a nice day mark
Mike in Mo
08-14-2003 06:04:12
 Re: need info on jd head gaskets for high compres in reply to mark, 08-13-2003 19:34:11
Mark Are you running the Deere gasket? I used to blow one about once a year until I switched to a FELPRO gasket, and haven't had any trouble since. It has a metal sheet in one side, and composite on the other. Get it thru an auto parts store, Part no. 7744SBX. I've seen a lot of different gasket coatings mentioned on this site, I paint with aluminum paint and put it on wet. As AR man said have the block and head checked and maybe deck them both 0.005" or 0.010" to make sure they are flat. Good luck, Mike
AR man
08-13-2003 21:48:52
copper is good not sure you can get anything else...check head and block for warpage biggest cause for leaks ive found...good luck...
mark
08-14-2003 20:20:16
 Re: Re: need info on jd head gaskets for high com in reply to AR man, 08-13-2003 21:48:52
head and block are ok had a jd head gasket. just wounding if copper would work , i have two new head gaskets copper on one side and metal on the other i think i will try them next.
