John Deere 70 Power Block Pistons
JD 70
08-13-2003 18:41:34
We're looking to buy a set of pistons for a JD 70 with Power Block. Anyone know where we could find a set? Thanks for your help.
2 Cylinder
08-14-2003 05:41:23
 Re: John Deere 70 Power Block Pistons in reply to JD 70, 08-13-2003 18:41:34
I ordered a set of high compression aluminum pistons (NEW)for a JD-A powerblock from Hinrichs Repair. They will make them to your specifications, oversize and for a stroker crank also. Phone # 815-778-1900 or 815-499-6580.
Tyler Neff
08-15-2003 11:00:02
 Re: Re: John Deere 70 Power Block Pistons in reply to 2 Cylinder, 08-14-2003 05:41:23
Dengler tractor sells piston that u can design to ur own specs.I believe the price is around $800.However depending on how big ya wanna go D pistons will work to with cylinder extentions,but be careful with stroke. The dengler piston goes up to 7" i think.Good Luck with ur project.
