wheelie bars
steve roberts
08-11-2003 19:03:05
can someone tell me the proper measurements behind wheel and height off ground. thanks
Jim M
08-11-2003 19:15:01
 Re: wheelie bars in reply to steve roberts, 08-11-2003 19:03:05
I think the pads need to be 5 inches square and the front of the pad to be behind the rear radius of the tire and to be 10" off the ground and at least 20" between them. If I'm wrong someone set me straight
2 cylinder
08-12-2003 05:19:40
 Re: Re: wheelie bars in reply to Jim M, 08-11-2003 19:15:01
They need to be 5" square pads, 20" apart, 10" off the ground, and usually 5" behind the outside radius of the rear tire. And be able to support the weight of the tractor in the classes you intend to pull in.
