looking for pulling block for my M
IRISH RED
08-09-2003 21:03:41
I am building an m and I was wondering what would be the best block to use except for the 450 block the tractor needs to be stock appering when i get done building for div 3 pulls
THANKS
FB
08-10-2003 09:58:54
 Re: looking for pulling block for my M in reply to IRISH RED, 08-09-2003 21:03:41
WELLLLL L if you can't use the 450 block than the 400 M and Super M block are all the same I THINK so just use your stock one, ANDDD if you want it built call lemmons, they can build farmalls that are 1 or 2nd every time IF you have the money
3-4-1 PULL
08-10-2003 08:43:05
Well first: 7 inch stroke
second: 4 3/8 bore and flat top pistons
third: 400 GAS head (not an LP head)
fourth: LP manifold
fifth: cam ground for THIS motor and diled in
sixth: electronic ignition
seventh: roller TIP rockers
eighth: carb modified to feed this motor
ninth: rocket govener
tenth: K&N filter
When you start pulling this set up get ready for victory lane,that is of corse you got the rest of the tractor set up right,,O by the way you SHOULD make about 140hp,ALSO if you want one of these motors built for you I can fix you up with the guy in Manchester Michigan that builds motors that BEATS Lemmons junks all the time.
littie guy
08-16-2003 05:22:45
 Re: Re: looking for pulling block for my M in reply to 3-4-1 PULL, 08-10-2003 08:43:05
Do not let the guy in manchester look at your engine. It will blow up for sure.
FB
08-11-2003 11:43:09
9th..a M&W rocket governor won't hold over 1600 rpm's i am told, and even a div 2 and 3 is 1760
supermpuller4
08-10-2003 19:20:52
Why don't you put a list of the pulls your tractor goes to , so we can see if you could beat Lemmons which I doubt you can , I'd like to see if your tractor runs as good as your mouth.
Bill
08-10-2003 19:40:13
 Re: Re: Re: looking for pulling block for my M in reply to supermpuller4, 08-10-2003 19:20:52
I still want to know why Lemmons wont go pull with the MMs that are 25 miles from him or if he does he pulls 4500 gets third loads up and goes home. I also like the story about a Tugger pull he went to and refused to unload his tractor because a certain Miss Minny was there they said he cried so hard they told the Minny he could only pull for exhibition.
3-4-1 PULL
08-10-2003 22:13:22
 Re: Re: Re: Re: looking for pulling block for my M in reply to Bill, 08-10-2003 19:40:13
J--k only runs for a short time, why does he waite so long to pull again?,why?,no water because it will leak like a sive,every time it runs it slowly dies,just watch all the smoke and blow-by as it goes down the track,you can allways tell a lemmons motor,,,HE can't build them like the cylinder doctor can,,,,,
IRISH RED
08-10-2003 11:16:30
Thanks for the info now were can I find the people you are talking about and how much is an engin going to cost is there any other IH blocks like the w-6 that would work thanks for all the help
