compression oliver 88
zig
08-06-2003 17:14:17
building 440 ci 88 how much compression should i run how much hp should exspect
brian
08-26-2003 21:08:56
 Re: compression oliver 88 in reply to zig, 08-06-2003 17:14:17
I have an 88 that I pull with 3 7/8 bore and the same stroke as you have. I would like to get larger pistons and was wondering what you were using and where to get them. Thankyou
TimC
08-07-2003 19:39:21
To many varibles. How many rpms are you going to turn. What are the cc's in the head. What bore, stroke, cam, intake, carb.
zig
08-08-2003 22:56:34
 Re: Re: compression oliver 88 in reply to TimC, 08-07-2003 19:39:21
2400 rpm 94cc 4.390 x 4.875 stock cam intake ported bendix carb 38 mm
TimC
08-09-2003 15:03:31
 Re: Re: Re: compression oliver 88 in reply to zig, 08-08-2003 22:56:34
I figure 12.44 to 1 ratio. I can only guess at 175 to 200 hp at 2 to 25 hundred rpm and 450 to 500 ft/lbs torque. I don't have a clue what the cam events are so this is just a wild guess. I figured it on 1.8 intake valves and 1.5 exhaust .
I also figured with 4.890 bore dia on head gasket at .030 thickness and .010 deck clearance. 94cc chamber volume.
This is just guess work. Good luck.
