Qusetions from a Tractor Pull Rookie
Mark D. Knight
08-06-2003 07:28:48
Although I grew up in a farm-equipment business, I'd never attended a pull (just seen 'em on TV and such) until last Saturday night at the Harrison County Fair in Corydon, IN. In the 5500# Farm Stock class, I noticed that the Co-op's and Cockshutts, and the Case tractors, didn't appear to be equipped with an engine governor at all...some of 'em were getting some mighty big revs, compared to the Farmalls, all of which were basically stock and running against the governor (one Super M even ran a stock muffler!). Did these tractors NOT come from the factory with a governor? Or, if they did, why was it legal for them to disable the governor but not the Farmall boys? While I noticed that the UNgovernored tractors took the "money" spots, the Farmalls were only a couple of feet short of what the other guys pulled...Also, the Co-ops and at least one Case in this class ran disc wheels, and fully enclosed engine compartments...the actual engine block was not visible from the side of the tractor. From what I recall growing up, those mods were DEFINITELY not stock...so what gives? Or are the Farmalls just so dominant that the other guys have to be given an advantage just to be competitive? I TRULY don't understand...can somebody explain this to me?
Farmall Boy
08-06-2003 12:36:01
 Re: Qusetions from a Tractor Pull Rookie in reply to Mark D. Knight, 08-06-2003 07:28:48
HAHA.....YUP those farmalls don't need all these high price upgrades to pull a STOCK class..those tractors in that class were probably too heavy to pull in that class stock...so they have used pressed steel to lighten their tractors up to 5500.. i pull a farmall M in the 4500 with a stock motor but it has been lightened up greatly...ALSO the co-op 's and case's were probably 6 cylinders compared to the farmall's 4...so the governor on the co-op's etc. governors were not able to be noticed while they opened up...OR some people put a solid bar in place of the governor spring, to make high RPM's, but their is no way for them to gain them back once thier lost...You outta pull its alot of fun
phil
08-06-2003 08:18:05
Mark, if you ever try to plow or disc with an ungoverned tractor, you will see why the governor was invented - it's almost impossible to hold the RPMs level with a boncing, varying load. So I'd bet that all of those tractors had governors once upon a time. As for having an advantage in a tractor pull, probably not. When the sled load is applied, the governor opens the throttle to "full open", you can't do more than that.
Mark D. Knight
08-06-2003 16:46:59
 Re: Re: Qusetions from a Tractor Pull Rookie in reply to phil, 08-06-2003 08:18:05
First, the Farmalls were only running 1600-1800 rpm...wide-open throttle (WOT) or not...whereas the others were cranking what I would estimate to have been in the 3000-4000 rpm range (and yes, a couple of them were Continental 6-cylinders). Awhile back, over on the BinderBulletin tech forum, I had asked a question about using a truck with an IH V-549 (approx. 1200 lbs over the front axle, with over 500 lb/ft of torque in stock form) as a puller...and I was told that, unless you could turn some serious rpm--above 5000--that it was useless to try to pull, because you lose the advantage of speed/momentum while the weight box is just getting started moving up the sled. So I guess my question is...is rpm/speed that important? And just what restrictions are there on "stock" tractors? I've got a '44 Farmall H (cast-iron shift knob calls it a '44 anyway) that needs rebuilt, and I'm considering building it for the stock class as a puller...So what advice can I get on building an H? I've read some posts by Chad that tell of building an H into the 70-80 HP range...how expensive, and how effective, and how legal in a "farm-stock" class?
phil
08-06-2003 17:48:19
 Re: Re: Re: Qusetions from a Tractor Pull Rookie in reply to Mark D. Knight, 08-06-2003 16:46:59
...is rpm/speed that important? Yes & No. The pullers that use a pair of Allison engines leave the line at full power, tires spinning near 60 mph. The idea is to get as much sled speed as possible, maybe 25 mph, before the weight starts their deceleration. The revs are kept at max, wheel speed still at 60 until the sled skids to a stop. Momentum & HP are the main parameters. Conversely, my antique tractor goes 1.5 mph. I use WOT while I'm 'driving' down the track toward the pull zone. When the front tires lift & the rear wheels slip, I throttle back to about half speed & slowly finish the last 30-50 feet of the pull. The tractor is probably developing less than 15 HP but it has plenty of torque to spin the tires. Momentum & HP are probably not important to me.
Mike
08-07-2003 18:17:36
 Re: Re: Re: Re: Qusetions from a Tractor Pull Rook in reply to phil, 08-06-2003 17:48:19
Speed /rpm ? You need to decide what wt. class ,and mile per hour you plan to pull, then build the tractor for that class.
Example: I pull a Case vai in a 2500 lbs 5.5 mph class. RPM's = HP , I need to get the sled moving quick .
