Starter on M puller
M Puller Too
08-05-2003 20:45:50
I pull an M Farmall almost every weekend. It's got a half inch stroke and high compression. My problem is after I pull, I have to let it idle for a few minutes before I shut it off, otherwise, the heat in the motor builds up too much compression for the starter to crank over. I've been pulling it for 2 years now so it's broken in. The starter is a stock M starter. I was wondering what some of you guys who pull Farmalls do to your starters to help overpower the compression. Is there any way to beef up the starter? Maybe ChadS or Ohio M Puller can help.
TimC
08-06-2003 20:47:06
 Re: Starter on M puller in reply to M Puller Too, 08-05-2003 20:45:50
You might try leaving the timing at what ever the motor pulls best at and turn the ignition on after you press the starter button. If it doesn't crank hot with the ignition off the timing has nothing to do with it. It will start a lot easier and save your starter to by geting it turning over first before you light it off.
M Puller Too
08-06-2003 08:29:54
Thank you guys for all the help. I set my timing last spring when I finished the rebuild, but I haven't checked it since. That's probably the problem. I have another starter that has been rebuilt. I'll probably check the timing and change to the better starter just to cover both remedies. Thanks again for the help.
ChadS
08-06-2003 08:21:24
I have had so much starter problems in the past, I wish I had a 100 dollars every time I replaced a starter on my Hs. I bought a rebuilt starter, and took it to a local starter shop and changed the windings from 6 to 12 volt. I also run a hot battery, 1000cca. I agree with Ohio M Puller, check your timing, make sure it is right. You don't have to change the windings if you wish not to, the 6 volt starter will hold 12 volts, just don't force it to start otherwise you might burn it up. Chads
Ohio M Puller
08-06-2003 08:03:47
It sounds to me that you may want to retard your timing about two degrees. Mark your original spot and then try it is the best I can tell you, we did have some trouble with ours doing that. We set it during the winter and it all had to be reset once this warmer weather set in.
My 2 sents
Ohio M Puller
M Puller Too
08-06-2003 08:02:56
It is a 1949 M with at two bolt starter.
Ohio M Puller
08-06-2003 08:07:26
 Re: Re: Starter on M puller in reply to M Puller Too, 08-06-2003 08:02:56
You don't need the 3 bolt starter, we are running a stock starter with no problem as well we are at 13.5 to 1 compression.
Ohio M Puller
Pete1468
08-06-2003 04:46:16
Do you have a Super M or MTA? If your trannsmission uses a 3 bolt starter it's very easy to fix the problem.
Jim
08-06-2003 07:36:36
 Re: Re: Starter on M puller in reply to Pete1468, 08-06-2003 04:46:16
Pete, Is it a secret or will you please tell us what the easy fix is for a 3 bolt starter? I am very interested. Thanks. Jim
DRT
08-06-2003 09:21:59
 Re: Re: Re: Starter on M puller in reply to Jim, 08-06-2003 07:36:36
No secret. Use a 560 diesel starter. Works great on my SM.
Pete1468
08-06-2003 17:51:16
 Re: Re: Re: Re: Starter on M puller in reply to DRT , 08-06-2003 09:21:59
A 560 starter was a little small for my motor, I had to use a starter off of a 1066 or the like. After I installed that I never had any problems at all.
