sealing cylinder sleeves
zig
08-05-2003 17:31:45
what is agood sealer to seal sleeves in oliver 88 and has any body running asolid block and do you have cooling problems
TimC
08-05-2003 20:48:06
 Re: sealing cylinder sleeves in reply to zig, 08-05-2003 17:31:45
In the next day or so I'll post a pick on brazing in the cyls on the top side. The bottom needs an epoxy before the sleeves are driven in then maybe and inch of hard block. This is for supporting the block when there is not much left between the cyls. The sleeve should have a .003 thousands interferance. Freeze the sleeves and they will go in with some elbow grease. There should be a step in the sleeve also that connects with the bottom of the block's step left by the boring bar.
They get hot if filled to the top. You can run them but back to back pulls on a long track are rough. If you get in a pull off on the first class you might be done for the day. You will also need an electric water pump and elctric fan if you want to make several pulls.
Its all my opinion so take it with a grain of salt.
LW
08-06-2003 11:25:56
 Re: Re: sealing cylinder sleeves in reply to TimC, 08-05-2003 20:48:06
.003 entirely to much! .0015max I would go for .001,.003 interference would buckle a thin wall sleeve, hard block filler won't stop water it may slow it up, silicone would be better and will stay pliable and will move with the expansion and contaction.
TimC
08-06-2003 12:51:56
 Re: Re: Re: sealing cylinder sleeves in reply to LW, 08-06-2003 11:25:56
Define thin wall sleeve, then we can get on the same page. If .003 is to much interferance then 275 lbs compression and up is going to egg shape the cyls anyway. All things have to be taken into consideration
LW
08-06-2003 17:46:25
 Re: Re: Re: Re: sealing cylinder sleeves in reply to TimC, 08-06-2003 12:51:56
.250 wall or less, mechanical interference is a much greater force than that of 275lbs of cyl pressure that is uniform, do you know what a .125 wall thickness of plain gray cast iron take from cyl. press. about 1,600 psi but mechanical forces will excede that very quickly like piston thrust, too much press on a sleeve etc. But do what ever you want to , I am just a dumb machinist.
TimC
08-07-2003 06:27:47
 Re: Re: Re: Re: Re: sealing cylinder sleeves in reply to LW, 08-06-2003 17:46:25
Well, you got me. .125 is a little lean. LA sleeve does not recommend wet sleeves less than .150. Recommended interfer fit is recommended at .0025. I was a half thousands off. I stand corrected.
JIm F.
08-06-2003 05:22:56
The Oliver engines have wet sleeves and basically fall into place. I have heard guys pouring in "Dry Block" about half way up the sleeves to seal them. This of course is done after the sleeves are installed, using 1/2 bolts and washers to hold the sleeves in place. Then turn the block upside down and pouring it in. Hope this helps, I have not done this personnally... yet.
TimC
08-06-2003 06:24:22
 Re: Re: Re: sealing cylinder sleeves in reply to JIm F., 08-06-2003 05:22:56
This could work if the you are not running a very big bore. You still run the risk of spliting down the middle of the block when the cement between the cyls (1/4 to 3/8 inch thick) crack due to heat. You also have gravity and moisture working against you. The concrete at the bottom of the block helps seal the water and doesn't absorb as much heat because the high cyl pressure and heat is localized at the top of the cyl.
