farmall air cleaner
LEE
08-02-2003 15:01:06
I took of my oil bath air cleaner of my H. is there a dry style air cleaner that will slip our the end bottom end of the carb. I seen dennys as them way to much money. What else will work
mpj
08-02-2003 20:40:24
 Re: farmall air cleaner in reply to LEE, 08-02-2003 15:01:06
If you go to k&n's web site you can figure out how big a filter you need for your engine by its size and rpms. A stock H dosent take a lot around $35.00 will get a k&n any large auto parts chain can order for you.
ChadS
08-02-2003 17:44:04
I went an muffler shop and had a pipe made that comes from the carb, and out the stock air cleaner hole in the hood. with a K&N filter. Cost me about 40 dollars. Hope this helps.ChadS
deadeye
08-03-2003 02:04:10
 Re: Re: farmall air cleaner in reply to ChadS, 08-02-2003 17:44:04
I used a bent pipe from carb up thru the hood, then put the Donaldson dry plastic trap that you can buy at Case/IH dealer. I think this system came out on the 560's if I recall.-----deadeye
