compressiom and horse power on a super m
red neck puller
08-01-2003 07:11:27
i have farmall super m with 4 inch or 4 1/8 inch high domded pistons. i was woundering the compression i should be getting out of them. i am only get about 100psi. also how much horse power i should get. (everything else is stock except i got rid of the points)
thanks
BUD BARENIE
08-04-2003 05:40:32
 Re: compressiom and horse power on a super m in reply to red neck puller, 08-01-2003 07:11:27
JUST WENT THROUGH THIS MESS WITH MY 1953 SUPER (m)
4-1/8" BORE !! AFTER REBUILD HAD EXACTLY 105 COMPRESSION. STOCK SAYS 120 (C) CHECK YOUR HEAD NUMBER ON THE TOP OF THE HEAD FRONT RITE SIDE IS A CASTING NUMBER !! IF IT SAYS
8777 THROUGH IT AWAY 8060D IS BETTER !!!
BUT YOU NEED A 450 GAS HEAD . HAVE YOU CC THE HEAD YET. I DID AN ENTIRE REBUILD PORTED AND POLISHED THE HEAD BIG CARB AND CAM !!! NEVER CHECKED THE HEAD CASTING NUMBER !!! ENDED UP WITH CRAPP !!!! JUST CHANGED THE HEAD AND STARTED PULLING AGAIN. IT'S LIKE A BRAND NEW DATE
SEE YAAAA
buickanddeere
08-01-2003 09:14:33
What camshaft? A stock engine can have more compression pressure than an engine with higher mechanical ratio domed pistons and a long duration cam.
ChadS
08-01-2003 15:26:38
 Re: Re: compressiom and horse power on a super m in reply to buickanddeere, 08-01-2003 09:14:33
Sounds like you have a large chambered head. I recently worked on a SM that had the same problem. We put on a 450gas head milled about 100 thousandths, and a thinner copper head gasket, his compression is now 185psi. Hope this helps ChadS
