Newbie puller questions.
Jeff D (NE WI)
07-31-2003 19:41:53
I am thinking this year on entering our county fairs tractor pull. I figure I can make a fool of myself with the best of them. I plan on using our Case 500 Diesel in the 8500 lb. class. I weighed it in at 8100 lbs.. It has no chloride in the tires, no wheel weights, rear tires fair, nothing done to the engine. Anything I need to do special? Add weight? Where? Or should I just scratch the idea. Any help would be appreciated. Thanks.
Milky2390
08-01-2003 15:35:52
 Re: Newbie puller questions. in reply to Jeff D (NE WI), 07-31-2003 19:41:53
Here in PA I pull a Case 600. If it is a tight track you will want to pull in first gear and make some kind of weight bracket for the front to add some suitcase weight. If you are going to be pulling much it is worth your while to make it so you can take the swinging drawbar off and use a shorter drawbar with a hook point just under the rear cover. You will have to add some washers under a pulling loop to get it to 20 inches or whatever the rules state as max hitch height. Too often I see guys pulling for the first time that just throw a twisted clevis on their drawbar and go pull. Go to a local pull and pay close attention to what people do for their drawbars and weight brackets. Don't just copy them try to improve it in some way. Joel
Steve from MO - ya might.
08-01-2003 08:05:04
Read and memorize the rule book for your event to see what is legal. Go to another county fair or similar tractor pull event and watch closely what the more successful guys do with their tractors. There might be quite a bit you can do in terms of weight and hitch placement, and tires.
FB
07-31-2003 20:08:12
get as close to weight limit as possible, no
matter by what means, raise the hich as high as
legal and as close as legal, ride the brakes
evenly, if one strts to spin faster than the
other, push down on it harder, if the front end
end raises more than 10 inches off the ground,
throttle down...OH YAH pull 1st gear of
course..LOTS OF LUK FB
Agent Orange
08-01-2003 04:43:34
 Re: Re: Newbie puller questions. in reply to FB, 07-31-2003 20:08:12
Sounds like a plan! Have fun!
Agent Orange
08-01-2003 04:42:22
Sounds lke a good plan! Have fun!
