Whats Your Tractor ?
R Gottshall
07-31-2003 18:42:57
I have been floating in this site for a while now. I feel like i know most of you and my hat is off to all of you, you are a great group. The question i have is , What kind of tractors do you all pull with. Big or little , 2 engines or a old steamer, I would love to know. Thanks Rick
Chad
08-14-2003 08:49:48
 Re: Whats Your Tractor ? in reply to R Gottshall, 07-31-2003 18:42:57
This year i built a 505 Cummins on Alcohol w/2 turbos that i run with a 1650 Oliver Rear End. I run in the Light Super Stock Class in NTPA and Badger State in WI. I had it as a Challenger but had to change the sheetmetal to 195 White to pull.
Dan
08-14-2003 08:37:29
I pull a 1950 Oliver with a detroit motor. I pull in the 10,000-12,500 pound classes. I have pulled it for about 5 or 6 years now and there isn't a tractor out there in the stock class that can touch it. Mine is stock with 120 hp and i have beaten IH tractors that are all Hypermax motors that push out over 250 hp. In a pure stock class nothing can hold a candle to it. One of the things that really helps is my tires. I run 18.4X38 Firestone Deep Treads. This year i pulled another 1950 that we have and that one beat the other one of mine but this one has bigger injectors and higher rpm's. Anyone else out there pull a 1950??
Puller504
08-09-2003 06:34:24
I won the 4500# stock class this year with my Allis Chalmers WD. This is the 3rd year in a row that I've won this class. My daughter pulls our IH 504 in the 5000# and 6000# stock classes. My son pulls our Oliver 1600 in the 6500#, 7000#, 7500# and 9000# stock classes. Makes for much family fun! Don
DONKSTER
08-04-2003 17:34:39
54 SM-TA
Agent Orange
08-01-2003 20:12:12
1950 Allis Chalmers WD -STOCK - (not even bored). 3700# & 4200# classes. Mostly at SATPA in SC. Having a great time!!!
marlowe
08-01-2003 19:32:54
53 massey 44 special and a to-20 ferguson once in awhile just for fun with the to-20
REDMAN
08-01-2003 14:45:14
1586 ih,706 rear end 436 ci p-pump going to 4 turbos,about 1800 hp.does that answer your question?
Super Steve
08-01-2003 20:09:17
 Re: Re: Whats Your Tractor ? in reply to REDMAN, 08-01-2003 14:45:14
can i have it?
REDMAN
08-02-2003 23:14:14
 Re: Re: Re: Whats Your Tractor ? in reply to Super Steve, 08-01-2003 20:09:17
no,but if you would like directions to build one i can help.
R Gottshall
08-01-2003 18:08:31
Thanks for the response. Now i know why you are the best in your field.
REDMAN
08-02-2003 23:17:13
 Re: Re: Re: Whats Your Tractor ? in reply to R Gottshall, 08-01-2003 18:08:31
hell,i'm the underdog!when i get it finished i'd guess i'll be around 750 hp light!
ChadS
08-02-2003 17:40:43
1940-1950-1954 Farmall Hs
