Stroking a 47A What's involved?
Jim Jones
07-31-2003 08:16:24
I have a 47A i pull with,I went with oversize pistons and head work last winter...power is ok,but I am not happy yet.Wondering what has to be done to increase the stroke. Thanks Jim.
john
08-01-2003 13:52:47
 Re: Stroking a 47A What's involved? in reply to Jim Jones, 07-31-2003 08:16:24
Recently having finished a 6.1" x 9.25" "A", don't know if I'd do it again. Cost is not a huge deal but the clearancing is time consuming. Most likely you would choose a stroke that will require cutting out the back of the crank case. Using a drill, angle and die grinder I managed to hack 2ea. 2"x9" sections out of the case. One must block the trans. gears from trans side with plenty of cloth/tape/cardboard. Then I epoxied in sheetmetal pans in the hole.
Even with clearanced 329 rods, I had to cut slots in the top of the case to allow the rods to swing through. I had the camshaft clearance ground for me but to clear the rods which worked well, however, the lobe of the cam hit the edge of the crank next to the rod journel. This required me to grind the inner half of the cam lobe away and grind a groove into the crankshaft.
I used a powerblock bored to 6.100" and am using a short piston, which gave me a fairly long 14.5" rod. The rods just did hit the edge of the sleeves in the case, so two notches were ground into the sleeve. I had my head shaved and fitted with Caterpiller intake valves. Easy job but the the chamber had to be unshrouded to put the valves back in the same place, this of course resulted in clearance problems between the valve head and the top of the block. Again the die grinder was a singin'. Two eyebrows were ground into the top of the block to clear the valves when open.
At anyrate, it is alot of work!!! If I had the money or brains, next time I'd probably buy a finished tractor and say I built it.
HOSEMAN
07-31-2003 10:49:57
I HAD A 48 A WITH POWER BLOCK AND STROKED 1/2"
HAD GOOD POWER BUT NEED MORE. GO TO 8.5 AT MIN.
a puller
07-31-2003 15:09:44
 Re: Re: Stroking a 47A What's involved? in reply to HOSEMAN, 07-31-2003 10:49:57
depending on what power you want, 7.25" stroke can be acheaved easy. just alot of grinding. We have an A with 6"x7.25 and had around 65 horse.
