M FARMALL
DWIGHT
07-30-2003 08:09:42
SORRY I MISLED SOME OF YOU ON THE PARTS I NEED. THEY ARE FOR A M FARMALL NOT A MOLINE. STILL NEED SOME SO TELL ME WHAT YOU HAVE. WOULD LIKE TO HAVE ABOUT 75HP OR UP WHEN FINISHED. THANKS, IN ADVANCE DWIGHT
ChadS
07-31-2003 14:10:48
 Re: M FARMALL in reply to DWIGHT, 07-30-2003 08:09:42
Getting 75 hp out of an M is not too hard to do at all! You could get 75 hp with mostly stock parts. I have gotten 82 hp out of a 4.25 bore M. Sounds crazy? But its true. You could accomplish this by buying a set of sleeve and pistons for a SM-450. and M rods. Find a 450 gas head, maybe machine a little off of it if you like, install a copper head gasket, and a SM-450 cam. Make sure you get high compression pistons! Makes an incredible difference for an old M! For less $$$$$$$$$$!!! ChadS
ChadS
07-31-2003 14:09:04
Getting 75 hp out of an M is not too hard to do at all! You could get 75 hp with mostly stock parts. I have gotten 82 hp out of a stock 4.25 bore M. Sounds crazy? But its true. You could accomplish this by buying a set of sleeve and pistons for a SM-450. and M rods. Find a 450 gas head, maybe machine a little off of it if you like, install a copper head gasket, and a SM-450 cam. Makes an incredible difference for an old M! For less $$$$$$$$$$!!! ChadS
FB
07-30-2003 10:44:07
don't know it a regular m block can hold 4 an a quarter, if not go with 4 inch and stroke it half an inch or just get an M&W crank...with the 4 and a quarter it'll be 326 cubes...should get 75 with a good carb tune up
deadeye
07-30-2003 18:29:40
 Re: Re: M FARMALL in reply to FB, 07-30-2003 10:44:07
Hate to tell you, but I have a block that will go in an "M" that measures 4 1/8 in. before we start.
FB
07-30-2003 20:22:55
 Re: Re: Re: M FARMALL in reply to deadeye, 07-30-2003 18:29:40
mmmmm mmmmm ...OK what is that about..that 281 and basically a 450 motor??
