m parts
DWIGHT
07-28-2003 20:37:28
OK GUYS, I NEED SOME PARTS TO BUILD A GOOD PULLING ENGINE. I HAVE A 1948 M THAT NEEDS A LOT MORE UMP TO IT. WHAT DO YOU HAVE. TKS, DWIGHT
a pulller
07-29-2003 08:09:12
 Re: m parts in reply to DWIGHT, 07-28-2003 20:37:28
I found this in the archives:
M-W makes a piston sleeve kit for 5 and 3/4 stroke and 4 1/4 bore using stock rods.All you need to do is stroke crank 1/2 in. and bore 264 or 281 block[281 has more meat] io fit sleeves.With other minor modifications it makes a nice running 326 cid engine.Kit # is 179 I beleive.
piston
07-29-2003 05:48:21
have some good mm parts make you a good puller
a puller
07-29-2003 07:42:32
 Re: Re: m parts in reply to piston, 07-29-2003 05:48:21
what do you have for a moline U to make a puller?
thanks, a puller
Andy
07-29-2003 20:43:50
 Re: Re: Re: m parts in reply to a puller, 07-29-2003 07:42:32
If you are looking for U puller parts I have a 403 crank, blocks and some misc heads for sale. Andy
piston
07-29-2003 18:57:05
sorry mr. puller i dont;
