DIESEL CAMSHAFTS?
Jon
07-28-2003 19:35:08
Does any one make comp. grind cams for 2 cylinder diesels? I have a JD 730 that I have tore down and was wondering if someone made or ground a comp. grind on the diesels. Thanks.
Wide Front SM Puller
07-28-2003 22:52:59
 Re: DIESEL CAMSHAFTS? in reply to Jon, 07-28-2003 19:35:08
Call Sonny at Bullett Cams. Olive Branch, MS.
Kenneth Buck
09-30-2003 06:25:39
 Re: Re: DIESEL CAMSHAFTS? in reply to Wide Front SM Puller, 07-28-2003 22:52:59
Need info on cam specs for 305CI in line four cylinder by CNH. Looking for moving maximum air under 35lbs of boost.
piston
07-29-2003 06:01:05
he did my cam also,runs very gooddddd ddddd .
Sweeper
07-30-2003 17:34:40
 Re: Re: Re: DIESEL CAMSHAFTS? in reply to piston, 07-29-2003 06:01:05
Call Big Sonny at Bullett Cams--662-893-5670.
