Getting more rpm's out of a WD?
Jim
07-28-2003 17:06:12
Can anyone tell me how to get more R's out of an Allis WD?
Gary
07-30-2003 17:28:22
 Re: Getting more rpm's out of a WD? in reply to Jim, 07-28-2003 17:06:12
Unhook the throttle linkage from the carb,then hook the choke rod to the throttle on the carb and pull out all the way
Don
07-29-2003 14:35:26
First start with a gov, spring out of a AC 180. Then you may want to cut the rod and install a turnbuckle so you can get more R's. If you want a bigger motor for the WD let me know have one for sale.
olllie
07-29-2003 13:30:21
throw away the governor if you haven't already
then spend money on a better cam, higher compression, double up the valve springs, it's endless.
