TRACTOR PULL TRUMAN MN
OLIVER NUT
07-21-2003 20:53:13
Tractor pull in Truman MN on Saturday July 26 2003 at John Deere STOCK CLASSES ONLY starting time 12:00 noon on HWY 15 north of I90
tractorpuller
07-24-2003 08:21:44
 Re: TRACTOR PULL TRUMAN MN in reply to OLIVER NUT, 07-21-2003 20:53:13
Funny how the rules say "stock tractors only, no modified" and "Only stock block, heads, and carbs allowed". Then right under that it allows Heisler and TSC aftermarket parts? Didn't Heisler and TSC make high perf parts for Deere's?? Looks like someone is making the rules around there tractor? Doesn't sound like a "stock" pull to me.
bill
07-22-2003 19:01:31
Tell me more. Weight class, rules, tires. Need more infor.then i will bring my oliver
oliver nut
07-22-2003 20:14:55
 Re: Re: TRACTOR PULL TRUMAN MN in reply to bill, 07-22-2003 19:01:31
General Rules ClassRules
� Any John Deer 2 Cylinder can pull
� All tractors must furnish a clevis or hooking device with 3" hole
� If weights or tractor parts fall off of tractor you will be disqualified � If tractor dies or kills off after10feet or more you will be disqualified
� All drivers must remain seated
� No restarts
� All weights must be fastened to tractor � Front weights must be no farther than 11' forward of rear axle
� Organizers may disqualify any tractor at their discretion
� 2 classes per tractor only
� All tractors must be 1959 or older
� Stock tractors only, no modified!
� Drawbar must be 18" or lower and at least 18" rear of center of rear axle
� Only one fuel, no dual fuels allowed
� Steel wheels will be allowed, but no tracks. Any size tire in any class
� Only stock block, heads, carbs allowed, gas manifold may be used
� After market parts by Heisler and TSC will be allowed
� All stock tractors will in low gear, unless equipped with a creeper gear, then 2nd may be used
� No weights to extend behind rear wheels
� 10% over stock RPM allowed, with lever against stop � No cut tires
� Intake draft system and filter must be OEM original
IH puller
07-23-2003 16:31:50
 Re: Re: Re: TRACTOR PULL TRUMAN MN in reply to oliver nut, 07-22-2003 20:14:55
Did I read this post right, only JD tractors are allowed to pull???? Can't the green tractors compete with the other colors or is it their drivers that are the problem. I know that there are some very strong Deeres out there, so.....
OLIVER NUT
07-24-2003 05:31:26
 Re: Re: Re: Re: TRACTOR PULL TRUMAN MN in reply to IH puller, 07-23-2003 16:31:50
Only having stock weights classes this year no open class Also any two cyl can pull and other color tractors can pull to. Very one welcome!
dirtslinger
07-22-2003 21:38:40
Are you guys going to have any open class pulls this year? Would really like to come over in your guys area again....was kinda disappointed when we got rained out last year....let me know....Thanks, and good luck with your pull!!
