Hello there! WE have a 15.5x38 max tire limit. Any cut on tires. Please note, this is a non points NIATPA pull, We are pulling distance at this pull, we usually pull percentage. Hook fees are 10.00 per hook for members, 12.00 for non members. We are only allowing 1 hook per class this time due to the high number tractors attending. weigh in is at 6-7:30 am pull starts at 8am sharp. Pulling heavy to light rotation. starting at 7500, 7000, 6500,6000,5500,5000,4500,4000. 4mph modified speed limit, 3mph farmstock speed limit. 70%payback. Rules for mods: drawbar is 18 from center of axle, 20 high. front weights cannot exceed 11 ft from rear axle, must have wheelie bars. 10%over rpms. 4 mph, any gear. (rpms occasionally checked) you can enter 4 classes per tractor. rules for farmstock: stock hitch style, 28"from center of rear axle, 18 high, 3 mph 1st gear only. 10%rpms stock in appearence, must have factory air cleaner. weights can only be placed on the wheels, front,and rear WHEEL weight brackets allowed, no suitcase weights on farmstock tractors. Please be there early for sign in, we are going to have a large number of tractors at Goshen. Thanks, any more info? let me know or call me at 574-893-7437 Chad, I have all contact infomation for the antique pull. HOPE TO SEE YOU THERE!!
