IH 153 CBIN COMBINE MOTER
Ed
07-18-2003 21:39:12
WHAT CAN I DO FOR HP,STROK,BORE,CAM,HEAD,CARB,INTAKE,GOV.THANK YOU FOR ENY INFO.
ChadS
07-19-2003 03:23:13
 Re: IH 153 CBIN COMBINE MOTER in reply to Ed, 07-18-2003 21:39:12
Did thay come out of a 203?
Ed
07-19-2003 11:12:15
 Re: Re: IH 153 CBIN COMBINE MOTER in reply to ChadS, 07-19-2003 03:23:13
I bought this engine out of a salvage yard the owner said it came out of a 203 combine.
ChadS
07-19-2003 12:26:30
 Re: Re: Re: IH 153 CBIN COMBINE MOTER in reply to Ed, 07-19-2003 11:12:15
I have a Super C that I put this engine in. It produced 45 hp at 540. I couldn't belive that it was that strong!
SUPERIOR SUPER SEE
07-20-2003 20:16:33
 Re: Re: Re: Re: IH 153 CBIN COMBINE MOTER in reply to ChadS, 07-19-2003 12:26:30
Heck! the 153 in my super-C makes 53hp,and all that is done is its got a 120th's over bore and the cam dialed in,I run second geer with 49-38's in 2750 and 3000 class and spin out,every place I pull that C I kick butt they hate to see me drive in with it on the trailer,sometimes I will weight it up to 3500 and pull in low geer and still finish in the top 3 or 4,and no its not just a bolt in and go you have to cutt off a half inch of input shaft and install a pilot bearing in the fly wheel were the old bushing was,let someone that has the skills do this,It will be worth it,someday Im going to just go all out with this motor and take it as far as it will go,,but for now Im having too much fun with it!
ChadS
07-21-2003 11:07:17
 Re: Re: Re: Re: Re: IH 153 CBIN COMBINE MOTER in reply to SUPERIOR SUPER SEE, 07-20-2003 20:16:33
Yes, I forgot about the pilot bearing. I think a C farmall is a real good tractor for a light weight puller. I heard of one down in southern Indiana has a SC that is 62 hp. He is very competitive with it on 15.5x38s. I don't know what could be done to it as far as going all out on the engine. I think the results could be surprizing! Glad to hear you are having fun! Good Luck!!
kjm
07-19-2003 20:36:26
Chad was that moter a bolt in ? Thanks KJM
ChadS
07-20-2003 11:48:30
 Re: Re: Re: Re: Re: IH 153 CBIN COMBINE MOTER in reply to kjm, 07-19-2003 20:36:26
Yes, it did bolt up to the Super C. there is a slight casting difference on the right side but all the bolt holes lined up.
Ed
07-20-2003 18:49:45
 Re: Re: Re: Re: Re: Re: IH 153 CBIN COMBINE MOTER in reply to ChadS, 07-20-2003 11:48:30
What size rear wheels and tires are you running on the Super C
ChadS
07-21-2003 10:12:52
 Re: Re: Re: Re: Re: Re: Re: IH 153 CBIN COMBINE MO in reply to Ed, 07-20-2003 18:49:45
12.4x36
