Farmall M Timing Curve
New to Pulling
07-18-2003 12:47:28
I have a 52 M with a 53 SM engine running 4.125" High Comp pistons on stock stroke. I'm using electronic ignition with a high voltage coil. What should the timing curve be approx. for this setup? Also, any ideas where I can get a overhaul kit for my IH distributor? Thanks
Dan
ChadS
07-18-2003 18:30:01
 Re: Farmall M Timing Curve in reply to New to Pulling, 07-18-2003 12:47:28
Setting the timing with a dyno is the best way, I would say somewhere around 22-28 degrees advance, Look in the past posts here at YT, (Farmall M timing) There is a description on how it could be done by ear. Good Luck.
dmp
07-19-2003 20:11:16
 Re: Re: Farmall M Timing Curve in reply to ChadS, 07-18-2003 18:30:01
25 degrees in our 450.
