4020 pulling (pump timing)
Jason
07-17-2003 21:43:23
I have a 4020 with a 450 head on the pump and no advance, it has been locked. What should I run for timing? I run with 466 cubes at 3000rpm. Any help will be greatfull.
REDMAN
07-18-2003 22:32:49
 Re: 4020 pulling (pump timing) in reply to Jason, 07-17-2003 21:43:23
on the red one i got i'm at 43 degrees,but it turns 6300 i would guess probably 30-35 degrees,assuming you will be running a turbo,if i was you i'd call columbus diesel in ohio and ask them,then you will know for sure.
