Lighter 70
Dan
08-15-2001 10:43:57
I have a 1954 JD 70 gas,weighs 6700 with 16.9 38 firestones.I need to shed some tractor weight.Where can I find some press steel hubs and rims? Does anyone make a aluminum radiator for this tractor?
G Taylor
08-15-2001 20:08:42
 Re: lighter 70 in reply to Dan, 08-15-2001 10:43:57
Is it standard with power steering to weigh that heavy? In order to turn those tall 16.9x38 tires with that fast 1st gear on a sticky track, she will have to be tuned up a little even in the 6500lb class. Is this working tractor or pulling only?
Mike in Mo
08-15-2001 19:38:50
Dan- do you want to keep your tractor close to stock or go hog wild with it? I can give you some ideas to try if you're want to get to 5500#. The pressed steel wheels will get you to 6500 wiyh some to spare. Check a 3020/4020 axle size to see if it's the same as a 70, hubs for those might fit. Mike
how to lighten a 70 G Taylor
08-16-2001 19:49:54
 Re: Re: lighter 70 in reply to Mike in Mo, 08-15-2001 19:38:50
Mike would you run through that lightening list please? Looking to get a few lbs off our 70 & would like to make sure I'm not overlooking something.
Mike in Mo
08-16-2001 20:29:04
 Re: Re: Re: lighter 70 in reply to how to lighten a 70 G Taylor , 08-16-2001 19:49:54
G Taylor 1 weld on 1/2" plate for hubs, cut off axles as short as possible. 2 remove rear basic housing, replace with sheet metal cover. 3 small platform, 2" conduit for seat mount, pan seat. 4 use a 1-2 gallon gas tank. 5 remove fan shaft and raditor-you can get 2 hooks wothout boiling if you keep run time to a bare minimum. 6 lightweight front hubs and Weld Draglite rims. Mix and match as\your rules/budget allows. Mike
JDGnut
08-17-2001 19:35:53
 Re: Re: Re: Re: lighter 70 in reply to Mike in Mo, 08-16-2001 20:29:04
Also remove the air cleaner and go to a dry type element. Like Mike said remove the rear stuff, or the complete housing, and have one made out of a thin metal, or find one made of AL... On the hubs, look for a set of clamp on dual hubs, and a set of pressed wheels. Also look for a LP manifold.. but I'm goin to gt started on th HP stuff.. U can do lots of things, just depends on how much $$$$ U want to spend.. JDGnut
Mike in Mo
08-15-2001 19:47:47
Dan I saw a post on the JD board about 70 hubs just after I replied to you. Looked like good info so ckeck it out. Mike
SteveV
08-16-2001 19:04:53
 Re: Re: Re: lighter 70 in reply to Mike in Mo, 08-15-2001 19:47:47
Hi Mike, send me your e-mail and I'll tell you about the State Fair in Sedalia...Probably 300 hooks and rain delays.
Steve
