M stroker Question
Brian
07-14-2003 10:10:56
I have an M and I am wanting to run 6.5" stroke and either 4.250 or 4.375 bore. I need to know what pistons and connecting rods would be right for this set up. I am new to pulling and really could use the help Thanks!!!
Flyin Farmall
07-14-2003 21:17:46
 Re: M stroker Question in reply to Brian, 07-14-2003 10:10:56
You can run a stock rod with a 6.5"stroke.Pistons can be a little tricky to find!
randy hall
07-14-2003 19:48:50
you will need to have connecting rods made. you need to talk to kieth merfeld.
ChadS
07-23-2003 17:29:35
 Re: Re: M stroker Question in reply to randy hall , 07-14-2003 19:48:50
Could you ues a chevy big block 454 piston? Small wrist pin, with the M rods might work.
