Need rubber Do you cut tires???
Adam P
07-10-2003 10:03:56
Howdy all!!! Well, I'll be the first to admit that I know nothing about pulling, but I hear you're a great group of folks!!!!
From what I understand, you "cut" your tires... Well I went to a show last weekend and saw some pullers and noticed the lug tires had the lugs cut down. I am doing a restoration on an antique, miniture, walkbehind crawler, and need to retread the track.... As it turns out, the lugs from a large size tire would work with only a little bit of modification on my part... Am I barking up the right tree????
Thanks in advance,
Adam P
[email protected]
Howard H.
07-13-2003 08:35:10
 Re: Need rubber Do you cut tires??? in reply to Adam P, 07-10-2003 10:03:56
Around here, our tire shops always have some tires out back in great shape except for a plow share or something cut through the side. That might help with what you want...
Howard H.
Grinder
07-11-2003 03:00:29
Adam: Most cut tire are worn down from normal farm use (road wear) then they are groung to get sharpened. sorry, but there are no tires lugs lying aroung, just a bunch of nasty rubber dust.
